Sean Harvey
Hello,nSo in this case you have X,Y and RotZ Inactive. That means the remote displacement Pilot node will not couple in that DOF, so if you did specify say 1mm on X component (where you have it set to Free right now, since X is inactive, the scoped to 6 edges you have will not get that 1mm displacement. Similarly for Y and RotZ. Does that help clarify?.Thank younSeann
