You can use either method. Overset is probably easiest to set up, but may have issues when running. MDM tends to be more difficult to set up but you may find it's slightly faster and you can use collision UDFs for when things get too close to each other. nThe cylinders can move as a single block or singly, it's for you do define during model set-up. n
