Pretty much. Patch a small amount of plastic into the domain first too, it'll help the solver around the boundary surface. The manual will cover the VOF settings, you'll want the scheme designed for transient flow. nUR factors can be left alone in most cases, control model stability with the time step. Similarly retain higher order discretisation schemes and turn on Higher Order Term Relaxation for all equations. n
