You cannot add new contacts to a simulation that is solved without solving it over again.nYou must put all the contacts you will eventually need into the model before you start, then use Contact Step Controls, where the contact is Inactive (dead) in Step 1 and Active (alive) in Step 2.nI would have to see the model or get a much more detailed explanation with images to comment on why something is moving when a contact comes alive.n
