September 18, 2020 at 11:20 am
Good afternoon Peteroznewman!nI would like to create a square mesh for my model. (Like in the picture below). I've read it is more appopriate mesh for mechanical analysis.n
nI have used Hex Dominant method in which the mesh creating lasted more than 10 hours and has got no result and i just finished the mesh building because i thought it cant be callculated for such a long time. I use pretty powerful computer with 320 gb RAM. However, the simple program controled mesh is calculated for 20 minutes.nAlso, i have sliced the geometry by peices and used sweep method but got an error that this method can't be used for a such geometry.nI also need help from you. Could you please advice me what to do to create a square mesh?nMy Desing Moderel file is attached. nnn
