September 18, 2020 at 2:54 pm
I want to apply some extra rigidity to the scoped faces (in a joint), neither zero nor infinity, so therefore I want to make use of the beam behavior settings. But I am confused how should I select the best and the most appropriate radius for this purpose? If we cannot make use of the beam behavior for either a joint or a beam connection, then why is it there, Sir?n
