September 18, 2020 at 3:27 pm
I didn't say you cannot make use of the beam behavior, I just don't recommend it.nYou can use beams between the scoped faces and the remote point, but the number of beams you get depends on the mesh on the scoped face, which is why I don't recommend it. There are special cases where beams can be useful, such as extracting forces along a long weld bead.nTo insert some flexibility between two parts, use a Bushing between the two faces. The Bushing definition provides specified spring rates in all six DOF. Those values won't change when you remesh. n
