Sean Harvey
Hello,nI wanted to point out that depending on the license you are using, you can use Ansys Material Designer to do homogenization both structural and thermal. Material Designer can be found in the Workbench Toolbox. The material could then be used in Ansys ACP.nThank younSeann
