HuiLiu
Hi did you try the smooth option as mentioned in the previous post? If smooth doesn't help, you will need to do a reverse engineering like mentioned, ie. cleanup the facet, shrink wrap, convert to solid etc. To reverse engineer the facet, you need to first export the STL file from the result of topology optimization, did you have that file?n
