September 19, 2020 at 6:04 pm
. I tried all the steps as you said. But it solves the whole model again. Can you check if the Analysis settings are correct ? In the Model, Spring Force remains constant, however I need to change the probing force . nSo, First System solves the spring force with probing force deactivated. While in the second system , probing force is activated and solved. The whole model solves again.nn
n
