September 20, 2020 at 2:52 pm
Thank you for your response .nThe force-time data used to simulate my geometry was an arbitrary force-time data, to get my simulation to work, that I found online. The actual force- time data will be measured during experimental testing of the beam geometry. nI will complete the calculations nevertheless, would the spring rate K, be calculated similar to the attached figure 1?n
Fig 1. Spring stiffness calculation nn
