Keyur Kanade
Do you want to update geometry or mesh?nThis looks like you get this warning in meshing. nIf you modify geometry and go to meshing then meshing tries to identify the meshing controls defined. e.g if you have selected some face and has given some face sizing. nIf geometry modification has altered that face then meshing can not find that face, Then meshing gives this warning. nPlease check all meshing controls and redefine them if required.nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
