September 21, 2020 at 1:31 pm
Hello- nFor the resonance frequency shift, you might need to do the optimization (Project Manager - Optimetrics - Add - Optimization) itself, by giving different parameter change according to different parts. nFor the Avg of E/H-field plots, you can use the Field Calculator (Project Manager - Field Overlays - Calculator) and create expression according to your need. (Please refer the help document for more details)nYes, this is the default assignation for any multiple ports in HFSS. You can change the power value if you want to analyze the antenna characteristics when both the ports are excited simultaneously.nHope this helps!nnBest Regards,n n
