The question is under fluids. So we assume you want to mesh fluid volume. nPlease create fluid volume first. nPlease check nOnce you get the fluid volume, please simplify it like removing those holes etc. nThen proceed to meshing. If you want to mesh for structural analysis, please create a post under preprocessing or structural mechanics category. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
New Post - Reply To: Mesh Issue
