If you're switching from one channel to the other and the gas side is all ammonia vapour then no, but you will need two fluid materials. If the gas side has (for example) air in it then yes as gas side will be a species mixture. n
New Post - Reply To: Setup for fluid flow in Membrane Contactor with 2 fluids in counter current flow
