Pluto922
There are 3 pictures. The first picture and the second picture are the same plane created by me. So why don't you could see ???nThe first picture is used by Auto Range in contour. The second picture is used by Clip to Range, which Min is 0 and max is 0, in contour. nLike second picture, Why is the blank part of the picture not displayed in the first picture ?nThe third picture is used by Auto Range in contour on other plane created by me. nI think that under normal circumstances, the first picture should be displayed like the third picture, which the right side will show the part where the DPM concentration is not zero.nHowever, in fact, the first picture is as you can see, and I want to know why it is not the same as the third picture.n
