October 9, 2020 at 5:22 am
Hi!nThanks for the solution! However, if I'm not able to pick the node in the GUI it will be very inconvenient to guess the location of the node. Is there any way of actually hiding the elements that are visually hidden by the section plane so that it is possible to select nodes in the GUI? n
Image copied from a similar post:nhttps://forum.ansys.com/discussion/comment/78591#Comment_78591n
