rtk
Hello - nYou can go for 'thicken sheet' option in order to make the sheets as solids.nWorkflow : Select the sheet ->>Modeler->>Surface->>Thicken Sheet. Give the adequate thickness (single side or both side) as per requirement. This allows you to assign materials as well.nFor more details on this, please refer the HFSS help document.nnBest Regards,nn
