naibaf
Thank you again. So as I understand I only remove it from phase continuity. Since I hook the function to the air-phase. So I need a second udf to remove it from continuity? Or do I hook it also to continuity? Since I only can hook mass sources to each phase and momentum sources to cellzone.nThank you in advance! And have a nice weekend!n
