Array Read this blog post.nArrayContact Miscellaneous. Turn On if Contact Based Force Reactions are desired. nThe useful part of the Contact Status is that the contacts are Sticking.nPlot the result data vs. Element Size. You should see the values converging on the true solution. A coarse mesh is an approximate solution.n
