October 10, 2020 at 7:39 pm
You have two Discussions going for the same model. Read my post here.nhttps://forum.ansys.com/discussion/13133/large-deformation-effects#latestnPlease choose one discussion for subsequent communications or we will be pointing to suggestions made in the other discussion all the time.nIs this problem Axisymmetric? The geometry looks like it is. If the loads are axisymmetric, then you should switch the model over to an Axisymmetric analysis.nhttps://forum.ansys.com/discussion/10021/axisymmetric-mechanical-model-tutorialn
