ValiullinDamir
Hello,Array!nI'm sorry for so long answer!nUnfortunately, i cannot find Target Normal, Couple U to Rot Constraint type. I have just these types of constraints:nAnd in the contact zone between shell and solid i have such a situation (with program controlled constraint type):nWhen i switch on Shell thickness effect in the contact property, i have stress concentrator (about 20% higher, than it should be), as seen in the picture. n
