Hi S1d996,nI'm searching info for using the 6DOF solver and see your questions. If you still looking for the answer. nFrom my point of view, the if statement did not work because you use
where =
should be used. As a result you might always get a False as the result for the if statement, thus, the change of load will never happen. nI'm not 100% percent sure if I'm correct but hope it would help you.nnAll the bestnXingchunn
