DrAmine
If you do want to run the case at isotherm T= 60?C (because material properties depend on that). You enable energy equation, initialize temperature to be 60?C, switch off energy equation under Solution Controls>Equations and run.nnIf you want to run with Energy equation: that is then straightforward..n
