Ashish Khemka
nnThe error message above indicates rigid body motion which indicates some of the part is unconstrained and can move freely. Using named selection can you see which part has the node indicated above. If it is bolt then you can use bonded contact for bolt head and shank to transfer pretension to clamped parts.nnRegards,nAshish Khemkan
