debugging user scripts does not come under support scope for Ansys employees on learning forum I hope others can chime in here.nJust to give you hint, Ansys workbench uses ironpython so search python for loop to get correct syntax.nYou are not using correct syntax. I hope that helps.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
