ANSYS_MMadore
The server information should be in C:\Program Files\ANSYSEM\Shared Files\Licensing\ansyslmd.ininWhat are you seeing for errors when you try to run HFSS with more than 4 cores, please share screenshots? Does it run if you only select to use 4 cores?.Thank youn
