try resetting the appdata folder helps?nIf you are using Windows, close Workbench, open up file explorer and reset your appdata:nfor that go to the following path in file explorer.n%appdata%\ansysnand rename the folder of the version you are using, e.g. v191 to v191.oldn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
