October 12, 2020 at 5:19 pm
Under the Definition tab of Topology Set, the Method is set to Automatic. This has been the default since prior to v19.1. The user can use the pull-down menu next to this setting and select other topology options that may be available but this typically isn't necessary. nIt's hard to tell the exact issue with your particular mesh. It may be related to the number of layers. Too many layers may cause wiggles in the mesh resulting from the spline fit through the defining layers. Too few layers might be generated to adequately define the geometry, especially if it varies significantly in the span-wise direction (this isn't common). I would contact ANSYS support to determine the exact cause of your meshing issue.n
