Reno Genest
Hi Leo,nnIf some client machines are not pointing correctly to the license server, then it will not work even if the license server is set up properly. Make sure the client machines are pointing to the correct license server.nAlso, can you send me the complete command line you used to get the following error?n *** Error 70004 (OTH+4)n invalid option on the command line:n Dyna_model1.kn E r r o r t e r m i n a t i o Thank you.nnReno.nn
