mateusredin
Hi guys!nI was reading the topic and realized that there is an easier way to solve this problem.nIf you check the documentation, you'll see that you can add nonlinear moment-angle relations with tabular data only for bushing, general Joints, and Radial Gaps. So you could substitute your revolute joint for a general joint with equivalent DOF unlocked.nOnce you selected your general joint in the tree, click Worksheet, and then you'll be able to right-click the corresponding stiffness cell and select Tabular data.nDespite the topic being already solved, thought it might be useful to someone.
