prashant
THANK YOU FOR YOUR COMMENTS.nI HAVE GONE THROUGH THE MANNUAL. AS PER MANNUAL, IN ONE WAY COUPLING FLUID PHASE INFLUENCE PARTICLE PHASE VIA DRAG AND TURBULENCE MOREOVER PARTICLE PHASE HAS NO INFLUENCE ON FLUID PHASE WHEREAS IN TWO WAY COUPLING BOTH PHASE INTERACT WITH EACH OTHER.nMY QUESTION IS IF I DID NOT PROVIDE VELOCITY TO PARTICLE (ONLY MASS FLOW RATE IS GIVEN) THEN THEY WILL FLOW IN THE DOMAIN DUE TO THE DRAG OF CONTINUOUS PHASE. IF NO HEAT TRANSFER IS CONSIDERED THEN IS IT A CASE OF ONE WAY COUPLING ?nYOUR RESPONSE IS SOLICITED.nn
