October 13, 2020 at 9:06 am
You define the automatic Export under File->Export->During Calculation. nFluent standard Post-Processing allows post processing particle tracks which you are doing all the time but you wanted to know how to create animations and I wanted to help you doing that.nThe export of hard copy can be done for a certain frequency via journal file for example where you hard copy particle tracks display (better if you add it to scene and hard copy that scene). The combination of steady state flow and unsteady particle tracking for hard copying objects is bit non intuitive here: you will need to hard copy images per iteration frequency or directly use the Solution Animation tool in Fluent and select the number of iterations to create the pictures.n
