It's not an error, the DPM model works on a point mass which is covered in the theory guide: it's also why the particles need to be smaller than the cells. So, yes a 1cm particle will fit through a 0.5micron hole. If you need to account for the diameter relative to channel size you may want to look at the macro particle model. n
