October 14, 2020 at 11:09 am
Hi Karthik,nThank you for your response. I am trying to simulate a bench mark case in the research paper Three computational methods for analysing thermal airflow distributions in the cooling of data centres. Please find below the screenshot from the research papern
nnThe following is the space claim model that I have created. I have also created an enclosure around the model for the fluid domainn
I have split the enclosure into two to represent the above floor fluid domain and the plenum. I could not complete the meshing due the errors. I used default settings without any local sizing, in fluent mosaic meshing.nI have tried following nSuppressed entire racks, CRAC, floor but my named selections disappeared when I suppressed those. I renamed the named selections again. Without the floor the flow occurred through the walls of the rack which was not expected.nSuppressed only racks and CRACS, but meshing errors was observed near the floor.nCould you please guide me to the good practices for modelling and simulation of data centers? Could you please point out the possible errors in my modelling?nThank you,nPratheek
