Judy Cooper
Hi Wulf22:nThis sound like there may be a setup error or corruption in the setup.nFor any Chemkin parameter study with multiple values, it should be possible to obtain a plot of end point vs. parameter or max point vs. parameter. nIf you set your X Variable to the parameter name, you should be able to select from the Y axis the max or end point value for the variable of interest, and get a plot of variable vs. parameter value.n
