October 14, 2020 at 5:26 pm
nif you plot any variable ( plot--> xy plot) against the curve length (the abscissa), and the line at which you plot is around the cylinder outlet edgenthe abscissa is (radius x theta)nnso if you write this xy plot to a filennyou can simply divide the curve length (the first column in the file) by cylinder radius then multiply by 180/pi to have theta in degrees. You xan directly plot agsinst theta or the angular coordinate: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/flu_ug/flu_ug_fvdefs.html you need there to set under cell zone conditions the axis rotation properly.nIf you still do not know how to do, I will need to record a video whenever I have time.n
