Kai
Hi, the model was not able to converge. I recommend that you plot Newton Raphson residual force and check which areas are causing unconvergence issue. My guess is the frctionless contacts. You may reduce normal contact stiffness under contact settings if the issue is related to contact. Also, you time step size is too large for a nonlinear problem. I would use 0.001 even smaller as min time step size.nThanks,nKain
