icellb1
Hi, @Sivagami,nCould you describe more details of your setup, we'll try to find someone to answer your question. For now, you can try reducing the complexity of your setup (create simpler geometry, reduce the ratio of biggest dimension to smallest dimension, make mesh coarser, etc). Also check you computer memory, usually at least 16 GB memory is need for many simulations.n
