jfonken
Hi Steve, nThanks for your explanation! I got it working this way. I have one other question regarding this topic. If I understand correctly, this method allows me to specify the local stabilization settings (as indicated in figure below).nHowever, I haven't been able to specify the global stabilization settings in the way described in the Ansys guide:nThe command in the first line of the picture below gives an error. It doesn't seem to find the Global Stabilization singleton, although it should be there following the Ansys System Coupling userguide. BTW, I'm using Ansys20.1.nDo you know how to specify the global stabilization settings?nThanks in advance!nn
