Aniket
JHPontes, Please check the help links:nSynchro command specifies whether the excitation frequency is synchronous or asynchronous with the rotational velocity of a structure.nOMEGA Specifies the rotational velocity of the structure.nnCOMEGA specifies the rotational velocity of an element component about a user-defined rotational axis.nand finally, for Rotordynamics analysis, please check:nandn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumnn
