Surya Deb
Hello, nFor such a case, where you need quite a bit of customization, I would recommend using DEFINE_DPM_DRAG UDF to customize the parameters.nYou can still use the main Stokes-Cunningham drag with the modifications that you need. Please check the link below for details on SC drag. nRegards,nSuryan
