DrAmine
Hi, as Rob said hard to describe foam that is why you can consider as one component fluid or multicomponent fluid. Further you might use a power law to describe its RH?OLOGIE.n Check this:7th International Conference on Fluid Mechanics, ICFM7nFoam fluid flow analysis in helical coiled tubing using CFDn
