October 15, 2020 at 6:46 pm
Hi, HG_Kwak,nSince you were not able to get the result after adding complexity to your model (e.g. add the induction pot), It seems that the main obstacle here is your computer memory, otherwise you can try adding mesh operations to create finer mesh, increasing refining per pass and maximum number of passes to help achieve <1% error. However these all require computer memory. Converging depends on many factors, if you want a specific answer to your question you may need to share more details about your model and make sure your computer memory is enough.n
