Govindan Nagappan
Remote point create a MPC constraint equation between the selected geometry and the point location. You can use the pin ball distance to limit the number of equations created. You have control over the behavior (rigid, deformable, coupled)nExamplenRed lines indicate the constraint equation:nnRemote displacement create a remote point. You can right click on remote displacement and select promote to remote point to see that in the tree. Then it provides you options to specify displacement at the remote point location. nWhat option to choose depends on what you are trying to simulate. From the description it is not very clear what you are trying to do. SO, I have provided a description on the remote point and remote displacementnTo see these red lines(constraint equation), you can click on solution information after you solve the model and switch to geometry in the graphics scree
