nI can help you transform your 2D model into a 3D model with the 2.5D characteristic of one cell in the extrude dimension.nClear the solution and clear the mesh, then save the Project. Now use File Archive to create a .wbpz file. Put that file in a .zip file. You can attach the .zip file to your reply.nIn your reply state the version of Ansys you are using.n
