VivekKamble
Hello, nHi there is no option to import .itf file to HFSS. If you want to add material manually to your current design. nYou can add, remove, and edit materials in two main ways:n1. Using the Tools > Edit Libraries > Materials menu command.n2. Under Definitions in the Project Manager, right-click Materials and select Edit Library.nif you edit an existing material, the edited version becomes a Project material and exists only within the current project. To make a new or modifiednmaterial available for other projects, you must export it to a user library and choose that library (or select Show all libraries) within the Select Definition dialog box.nn n
