assuming you are using 2020R2, if you are using local help, the links that I mentioned above have local path as:nhelp/wb2_help/wb2h_modal_acousAN.htmlnandnhelp/wb2_help/wb2h_hamonic_acousticAN.htmlnwhich you should be able to navigate to go to page function.nBtw which license are you using?nIdeally with student license one should see these two systems, if I am not mistaken.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumnn
