Can you try to export STL from the result in System B and then try to manipulate it in SpaceClaim instead of DM? That way would give you a better flexibility to clean the model, but you will need some cleanup in SpaceClaim.nIf you change the geometry type in DM to DesignModeler instead of workbench you will see the similar issue in DM as well.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumnn
