ANSYS_MMadore
For the configuration failure, please try setting the environment variable ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 to get around the problem.nnFor guidance on creating an Environment Variable please refer to this link. You need to create a NEW Variable.nhttps://docs.oracle.com/en/database/oracle/r-enterprise/1.5.1/oread/creating-and-modifying-environment-variables-on-windows.html#GUID-DD6F9982-60D5-48F6-8270-A27EC53807D0nnNew Variable Name:ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLLnNew Variable Value:1nnCan you search your C:drive for MSVCP140.dll to see if the file exists? Please also open a Windows command prompt and run the command set PATH and send the full output.nnThanksnMattn
